WISCOPAR
OK. Per the original build sheet my car came with 3:54 gears. Now....I've never had a car with this gear before but I swear what's in the car is much lower. I've had 3:23's and 3:73's both behind 727 trannys. My GTX is a 4-speed.
The gears are low enough, that I don't dare run it down the interstate.
Is there a way to tell (short of tearing apart the differential) what gears are currently in the dana 60?
I'm convinced someone, at some point switched out the rear gears.
Any thoughts or ideas are appreciated.
Thanks,
Will
Thanks,
Will
