- 7:22 AM
- Sep 5, 2022
- Mülheim an der Ruhr, Germany
Hello FBBO,
I have a question and maybe you can help me.
In a standard (original) gearshift from 1968 is a cable or wire installed, which releases the lock for switching, if you press the button above. In many cars this cable is broken, because many do not know how to disassemble this mechanism correctly and then just pull it until it breaks.
It is a braided wire which has a grub screw at both ends. at the top it holds the shift button and at the bottom the split which locks the gear.
Do you know if you can buy this? If not and you also had the problem, how did you solve it?
I marked where the cable goes in red on the picture. It is inside the lever.
