Getting started on my next project
ga66mopar
11:59 AM
North Ga
This is a one owner car with the original paint. It's has the original 383 with auto with 323 posi. So far it looks like a solid car. Here's some pictures before I start taking it apart.
A few more. I'm thinking about doing a 451 with this one for more header clearance.
Wow, Looks like a great base to start with. I dont see any rust anywhere. Looks very solid. Keep us posted on progress.
Thats a great looking car there, I would be real tempted into driving that a summer as is!! Good luck its a beauty for sure..
I was first thinking about going with more of a solid moroon like the chevy 1962 Honduras Maroon but now I'm thinking about staying with the original dark red metallic paint. I want something that really pop with the gray torq thrust wheels. My painter can't get too my car for 6 months so I have plenty time to decide. Taking out the k-member with the engine and trans today.
I Like!
The body looks great , It looks like a great car to begin with, good luck on your project, keep us posted... The 451 is a good idea, "but" you could just build a decent 0.03" over bore 383 block w/3.75" stroke 440 crank turn down to between 7.125"-7.250" counter weight diameter & have the mains turned to the proper diameter also, so it will fit in a B-series block, you would get 432ci out of your 383 & be just as good (Shy 19ci though) as the 451ci/400 base B-engine & you will be able maintain the original 383 numbers matching block.... Check Mancini Racing or 440source.com for full piston, rod, crankshaft & ready to drop in kits
I thought about using the 383 instead of a 400 and I may do that. I'm sure you're right about seeing little different between the two.
This project has been waiting for 2 years. Got the k member out and powder coated. Been scraping undercoating off for a few months. I have decided to keep the 383 and stroke it. I fitted the wheels before I took it apart. I guess I was a little burnt out after building the black car. After buying the 67 GTX and 70 RR projects the 66 got put on the back burner.
thanks for the update, looks good with those wheels too
that Plymouth looks sweet just as it is!
from one ga mopar guy to another great car for building,we will be looking at the progress,where do you keep finding those torque thrust wheels at?i wish i could fine some use ones.
