Gluing Console Carpet?
dodge68charger
1:25 PM
Washington
Do I Glue It Flush All The Way Around The Abs Side Cover And Notch Out Where The Clips Go?
Cars a 4 -Speed
Thank You
Test fit it with the trim before you spray any glue. I laid the old stuff over the back of the new and marked the holes.
How Did You Finish Where The Screw Hole Goes To The Very Front Bracket Through The Side Cover And Carpet?
The screw will pull through the carpet when you tighten it. Basically disappears. Or you can lift the carpet up a little and install it that way.
From the factory, there is a chrome countersunk washer around the screw. If yours was apart once, it may have gotten lost.
Im Sure Its Gone. I ll See If I Can Find a Pic..
Is There An Order To Install All The Console Parts and Shifter Boots, Etc
cars a 4 Speed
