plymouth67
Panel bonding usually has 3 times the tensile strength of a weld and seals the complete surface it is applied to from rust. The epoxy is the same type of stuff they have used to put the fiberglass tops on conversion vans for 30 years. When was the last time you were driving down the road and saw one of those flying off. I generally butt weld anything you may see like quarters as you can see the overlap in the trunk but, if I'm patching a door or fender or some other spot where you wont see it I will panel bond. No warping and the epoxy squeezes out of the joint and requires way less filler work. If I were going to flange and overlap a skin on a quarter I would use the panel bond....I just dont do it because I dont want to see the seam from the trunk.
