Good Rebuild-able 440 or 440 block WANTED in or close to VA
sls001
New Member
1:16 PM
VA
Feedback: +0 / =0 / -0
I am looking for a good 440 block w\main caps or a rebuildable engine, short-block etc in VA...
Seems all the ones advertised in VA people think are Gold or the ones at a good price are a 1,000 miles away.
Edit: i'm planning on building a high torque stroker for a 4x4 truck which is a daily driver, used for towing, hauling, and playing off road.
I am also interested in a BB 727 trans housing as well.
Thank you,
Not certain why my original message isn't showing up so here it goes again:
I am looking for a good 440 block, short block or even a rebuildable 440 in or very close to VA
Seems all the ones I find in VA people think are Gold and all the good priced ones are too far away.
Edit: I'm plan on building a high-torque stroker engine for a 4-wheel drive truck that I use daily also for towing, hauling, off-roading, etc...
Thank you,
Shawn
im not much help , but i do have a BB rear sump truck oil pan if you find yourself needing one
i got my complete 74 440 for 250 bucks and my rebuilt 727 for 200 bucks..motor had a frozen piston, if not for that it would have ran..iv seen a few 440s on craigslist under 500 bucks..
Where in VA are you located?
Fredericksburg
I check CL everyday and they rarely pop-up and the last block I saw close by the guy wanted $750 for it and it was a nothing special block. I see them offered on here, A-body forums and Moparts but they are normally to far away.
How far are you from Fredericksburg or Richmond VA?
Thanks
Im in Baltimore. Just pulled the 440 out of my 87 ram. It was running. Going to a 360 with a 46rh trans. It has the rear sump oil pan on it and truck motor mount brackets. And truck headers. I want to keep the valve covers. Have a 727 that i took out of a 70 fury cop car. 600 for both. Depending on what you want to do i have other items.
