Phantom440
Hey all, I hope you're doing well!
I'm slowly working my way through converting the Coronet from a 904 to an 833. Began the pedal swap last weekend. Got the previous (short) pedal shaft out, dropped the bigger automatic brake pedal.
Then realized the previous pedal shaft was covered in this thick grease, and I assume I need to put a similar grease on the new pedal shaft. Is there a particular brand or type you recommend?
Also; there's the support that goes on the outer side of the firewall to bolt the additional brace to- kind of a dogbone looking piece with a stud on either end. Do I need to add any kind of sealant around these holes to prevent water getting in there?
Thank you!
(And I apologize if this has already been answered- I tried to search the forums and found questions related to greasing the Z-bar and pivot hardware under the car- nothing specifically about the pedal assembly.)
(Also, I'm going the diaphragm route, so there's no overcenter spring doghouse)
Thank you!
