Ground wire
Aron Gleason
2:52 AM
Washington
Looking for ideas on where to put more ground wires/ strap with pictures. Already got a ground strap going from firewall to motor.
Electronic ignition module to engine. Engine to one of the master cylinder bolts. 440'
Multiple ground wires are not a good thing. Why do you want more than battery to engine and a battery (or engine) to body ground??
I've been told the more the better. But at least 3 more ground wires.
Where does everyone have the ground wire for the msd box going to? I have mine on the fenderwell.
The Factory Chassis ground was minimal at best. Add a few modern day accessories and Yikes.. I run a large cable from the back of the Cylinder head to the trans Crossmember. Neat, clean and out of site.
Working on a friends car and when you use the Turn signals, the interior lights flash. Engine Ground was loose and Chassis ground was just a few strands.
Multiple grounds are basically good, but can also cover up for other grounds that may not be good and should be fixed before adding more grounds.
