Does anyone make solid bushings for sway bar end links? Also, what can you tell me about drag links and panhard bars?
Check this out starting with post # 252.Does anyone make solid bushings for sway bar end links? Also, what can you tell me about drag links and panhard bars?
Polyurethane is close to solid.Does anyone make solid bushings for sway bar end links? Also, what can you tell me about drag links and panhard bars?
I have a 1-3/8" Hotchkis front sway bar with Poly end link bushings and 3/4" rear sway bar from Firm Feel and I concur!For handling I have found that going with the largest front sway bar you can find and then use poly bushings at every point on the sway bar system.
I have a 68 T/C wagon and when I redid the front suspension I went with all rubber and the stock 15/16 sway bar, it would lean like a drunkin cow when driving through curves. So I ordered a 1.125" Firm feel bar and converted the link and lower control arm ends so i could run simple and readily available poly bushings....now even with the weight of the big old C-body wagon with it's 440 it handles amazing!
Excellent point KD - yes, the Hotchkis bar is hollow and larger diameter.The 1 3/8” bar is hollow.
I’ve had difficulty getting clear answers on the physics of hollow versus solid sway bars. The comparison between the two always requires the hollow bars to have an overall larger diameter than a solid to have equal strength.
The rationale behind them is reduced weight. As the bar twists, the closer to the center matters the least in terms of torsional strength. Still, how thick is the actual steel in the bar? If there is a hollow center that measures 1/4”, is the bar actually equal to an 1 1:8” solid?
I’ve asked this question and never get a straight answer. Supposedly, the gains in outer diameter outweigh the losses of being hollow in the center but what math equation proves that?
