Has Anyone Used the Staples in this Cat Whiskers Kit?
Dibbons
5:54 AM
La Paz, B.C.S., Mexico
It's time to replace the door panels and the inner whisker things that go up against the window glass. I am getting a little aprehensive about the installation. The outer door whiskers just screwed on, these inner ones don't. I have a package of loose staples that came with the product. Now what? Thank you.
http://shoptntparts.com/1971-72-charger-topcatwhiskers-window-felt-kit/
Almost impossible to replicate the factory staples. On my Coronet I popped in rivets - get the smallest available from Harbor Freight. Once they're in you can't see them and they lie beneath the felt so the windows won't scratch.
I did something similar. Mine came with sheet metal screws but I switched them out for small nuts and bolts. I think they were a size 6
I sat down at the picnic table in my garage and drilled all the holes I deemed necessary through the "fuzzys" and the steel door panel top and installed the furnished staples-bent over with tools. I used small Vise Grips to keep the units tight and some spring clamps as well. They turned out great and the staples are only visible if you look for them.
Mike
