Heat Shield Location Help
rklewis1005
4:05 PM
1970 Dodge Charger, 383 HP, Auto
Good afternoon, I have the 2 brackets below (painted orange). I know the first one (first pic) goes on the right side mounted between cyl 6 & 8 under the head bolts. I'm not sure where the 2nd bracket goes (2nd and 3rd pic) - does anyone recognize it?
Also, the 4th picture is of what I've seen posted for cyl 7, mounted using the exhaust manifold mounting fastener. I don't seem to have that bracket - it's available, but wanted to be sure I need it before buying. Does the 2nd orange bracket replace it?
Thanks in advance for any information. I'm sorry if it's coming out clear as mud.
Ross
Ross
The pictured part is the lower part of the carburetor air heater, or heat stove. The placement of the part is shown in the following diagram:
The two parts of the heat stove were originally painted black, but rusted over time as the paint came off. The left manifold has a cast in ridge and bolt/stud bosses to mount the parts.
Ok, I think that helps! So I still need to purchase the Cyl #7 Sheild (small one)
On that bracket for the heat stove, should there be a retainer clip for the screw? Any insight into what it looks like?
