Runner71
Haha you right, but it's less complicated with the cars. Guess i just have to buy something before 70 and keep the 71 and try to enjoy them both. Expensive but hey money comes and goes hopefully the cars stay!
I have felt the same way since they were new, and I knew it had to do with the wide, rounded rear 1/4 panels and how they looked "off" with stock width tires, but your description nailed it! I have always wanted to like the way they looked, but the rear quarters' bulge and stock width tires look was something I couldn't get past. My Mopar brother/best friend and I went to Bristol back in the 80s for a Mopar only drag race (awesome track-thunder valley) and there was a tubbed 71 RR there with fat rear tires, lowered, with ground effects and that car looked GREAT! So for me, tubbed with fat rear tires did the trick, along with not having so much "space" between the rounded bottom of the sides of the car and the ground. I had a 71 Charger R/T back in 78+79, and they need wide rear tires too.The 71-74 Satellite/Road Runner/GTX models REALLY need wider tires with more offset. I think that I may have overlooked them for so long because on stock width wheels, the car looks like an elephant standing on a small stool, just tucked under with a narrow stance. The NASCAR versions had the cars hunkered down with huge tires pushed out wide, giving the cars a real aggressive look. If that look can be pulled off for the street, I like it.
Do you know what rear end ratio you have? I had a 3.23 in my 71 Charger R/T auto, 8 3/4. I thought that was OK as an all around rear gear, BUT now I have a 3.54 in a Dana and a 4 speed in my RR, and I like it!Lets say i stroke it, between 450-500hp and starts tweeking the gear ratio. Isn't like im strangle the hp so it feels less or is its just a must.. i mean now i cruz about 60mph on the highway otherwise the rpm goes to high.. or just that i can go longer on the gears?
Sweet car bio, really nice!!
To get to the point, find out what rear gear ratio you have. Think about whether you plan on/enjoy "top speed" runs on the highway or quick sprints on the street or track. At the track, do you run 1/8th or 1/4 mile? What I have found is that there is no way that I can compete for fastest car, and there aren't those many opportunities to go really fast, but quick is a lot more fun, much more useable, and I run 1/4 mile tracks, so I'm not talking about some crazy high rear end gear, but if you went from a 3.23 to a 3.91 the difference would be pretty noticeable. NOTE: If "going faster than 60 makes the rpm go too high" right now, it sounds like you already have a very high rear end gear already.
If you go from the 400 you have to a stroker kit in your block, that will be a major game changer too! We used to think of the 400s with their pitifully low compression as boat anchors, but a stroker kit, cam, heads, etc turn those into one of the most desirable motors!
I get nostalgic when I see the inside of a 71 Roadrunner. Identical to my 71 Charger.
Same page, the box fenders have to be full of rubber & well inside the wheel wells, no gaps in between arch & wheel. Are those 68 corner markers in front fenders? Sure looks a lot better than the oversized rectangular markers. A good looking car.This is a car that made the rounds in the magazines in the early 2000s. Some don't like the big wheel look but I feel the opposite. The large wheelwells and "fuselage" styling absolutely need wide tires to make the car look right.
I saw this car up close in Las Vegas 2003. View attachment 510259
What are Your RPM's right now @ 60 mph? With 3:23 butt gearing, You should be able to cruise @ 70 mph @ less than 3000 rpm. My Dodge Fireball class C RV has 4:10 rear gear...a 360/727, & at 55 mph i'm turning just about 3000 rpm.It's gonna be for 1/4m and quick runs at street, i think 1/8 is way to much for a "daily" in the long run. It's not way to high on the rpm at 60mph but it's just feels like thats were it's most comfortable at highway! Can speed 90mph easy but its just feels more "stressful" judging the sound. Haven't opened and checked inside yet but i would belive that's it original 3.23.. so start with the motor check the rear end and see how it's drive and take it from there. Anyone knows how the McLeod Racing 75209, Super streetpro clutch is? Thinking i need a new and better one.
Why not install a tachometer? Surprises me Your car does not have factory tach....it's a Road Runner, right?I have no ide why i typed 90mph i was trying to type 70mph haha no rpm gauge in the car so i really dont know. But yea i think its somewhere around 3000 at 70mph. Guess i'll pull the cover and see
