benno440
just chasing some info on venting in the fuel tank, 68 charger factory tank, it has a lockable gas cap and on the fuel pickup it has 2 tubes one for the outlet to carb and the other smaller diameter hose runs up the filer neck to the gas cap i am guessing this is the vent line.
i have just welded a bung into the filler neck for my -4 an return line from the regulator.
the later model b bodies have multiple vent lines am i right?
the single vent line on my car is the sufficient venting? for my 450gph fuel pump?
when i primed my new fuel lines i put a rag in the gas cap and put the compressed air into it after a min or so when i stopped the pressure was so high i neally knocked myself out, is this right?
if i do need more venting what would you suggest?
thanks in advance
thanks in advance
