Mopar1966bro
Upgrade my 66 to electronic ignition iv watched to many videos how should I hook up to the old dodge wires
Electronic ignition the coil and ballast how should I wire up the start and run wires from my old wire harness to the knew electronic ignition im not sure on how toLots of help here but you're going to need to be way more specific and show us some pics of what you're working on.
Do you realize how many ignition systems are available? We may help if you tell us what you have.Electronic ignition the coil and ballast how should I wire up the start and run wires from my old wire harness to the knew electronic ignition im not sure on how to
I don't even understand that really really short title!! 66 Charger is all I got from it all.Do you realize how many ignition systems are available? We may help if you tell us what you have.
Mike
Sorry very true it's the proform electronic distributer up grade kit distributer module ballast resister I im down to hooking up the S start and the R run wires I need to find witch way to correctly hook them up to my car iv hurd a couple ways the the positive side of coil to the s wire and negative side to the r wire run run the s wire straight to positive side coil byepassing the resister ? The wire diagram is positive side coil to ballast with the s wire and negative side ballast to other side ballast with the r wireDo you realize how many ignition systems are available? We may help if you tell us what you have.
Mike
Sorry sick of the internet write now and knew to texxibgI don't even understand that really really short title!! 66 Charger is all I got from it all.![]()
Yes it came with instructions but I came on here to get abuse not spell words I know it's spelt wrong didnt think it made a dif you know what im saying but thanks for the kind words Mr spellingYou can't spell either, I can barely understand what you are saying other than you are trying to install an electronic ignition. That Proform system isn't the best. The kit did not come with paper instructions?
My ? Is what is the best way to find the S start and the R run wires on my charger in your opinion so I can finish the wire both of witch are hooked to each side of the ballast I have done located and red and used my meter I need other input a second opinion I hope this is better spelt and understood sirYou can't spell either, I can barely understand what you are saying other than you are trying to install an electronic ignition. That Proform system isn't the best. The kit did not come with paper instructions?
