Help with engine id
BIGBOY
6:07 AM
wild west
Bought this 66Bel that had a total resto and a 440 put in.
Trying to determine what this 440 was out of and what year it is.
The engine has heavy coats of paint, so I can’t make out all numbers
Even using goof off and light sanding, but here is what I have found
On the side of the block I found 3c138585 and 3698830 440 9 DN
On the front pad j 440
9 26 2
again maybe missing some digits due to paint and eye sight
thanks
Thanks any idea what model car it could have come out of ? Is it a decent block ?
The blocks are all fine. If you're building a real race motor, you need to sonic check the cylinder wall thickness. Other than that just run it.
