- 4:52 PM
- Jan 16, 2011
- NorCal Sierras
I've had several sets of Hedman's over the decades
on Low-deck B engines, shorty block huggers & long tube 1-7/8"
never had any issues, none like described anyway
must be the RB raised blocks higher wider block causing issues/clearances
pushes the headers up higher & the RB headers usually angles the headers
off the heads slightly which inturn, make them closer to the starter
the Low-deck B engine headers
don't usually hug the block as tight they go straighter down
or don't always have such a tight angle/bends immediately after
exiting the exhaust ports
most my headers now are a custom build anyway,
properly routed & sized/length with 4-2-1 merge collectors
for my specific build needs/combos
I have had some Schumacher Creative Industries,
that were really nice, breeze to install, but far more $$$,
like the TTI's & Dougs are $400+ - $800+ range
http://www.engine-swaps.com/
I find it funny sometimes that,
why put thousands of $$$ in your engine ?
& just bolt on a set of $150 cheapo headers ? {Than complain}
makes no sense to me & it never has, never will...
especially any 2" header & 3.5" collectors
are going to be an issue on these cars, regardless who makes them
especially if the stock K-member, power steering or completely different steering boxes
or quick ratio arms etc., or just worn out & saggy/squised eng. oe style mounts,
{they make shims for them, even when new, Schumacher Creative Services}
{use the stock starter} & torsion bars are retained or add larger dia. torsion bars...
When it all effects & take room away from the exhaust...
most mass produced header mfgrs have extensive fitment notes too,
some people just ignore them too
one size doesn't fit all,
it is never intended to either & it shouldn't
IMO Some people get really cheap in the wrong places...
