Rackarboda
I have been having these problems with a studdering and coughing 383 since I bought the car a year ago. If I put a little effort on the pedal it almost sounds like it’s going to die before it makes a loud sneeze in the carb and pulls off a little. Feels like maybe 100 bhp. Flooring the pedal doesn’t make it either, hesitation at first, a cough, the engine revs and eventually coughs some more. At idle it sounds quite ok, but when cruising it feels like small hic-ups every now and then.
When I bought the car it had an Edelbrock 750 that I fiddled with a little before trying two other Holleys, and finally bought a restored Carter just to be sure. Nothing. Tried to adjust the mixture screws without any luck, if I screw them inwards the idle decreases around a turn from the bottom, but when unscrewing I can go on forever without any result. Changed the sparkplugs and wires, switched to a Pertronix ignitor and coil and swapped the distributor cap. I have checked the firing order maybe 10 times.
Finally took out the engine and had it apart. Cleaned everything, swapped timing chain and gears (looked like crap), fuel pushrod, and had the heads/valves renovated. Really hoped it would make a big difference, but absolutely no luck. Cleaned the fuel lines and even connected the hose directly to a small dispenser just to try. Checked for vacuum leaks.
It’s starting to get really frustrating and I’m running out of options. My last resort in mind is to try with an electric fuel pump, or else I have no idea what to do next. Any opinions?
