Hi-Po Exhaust Manifold?
robinsonwr
2:08 AM
Carriere, ms
I have a 1966 Satellite that I am transplanting a 440 into. My question is whether or not the 67-70 hi-po manifolds will work? If so which casting numbers should I look for?
I had a 66 Satellite 361 2-bbl, had a 383 4-bbl rebuilt for it and used the hi-po exhaust manifolds. They fit fine.
The engine compartment is the same dimensions as the 70 B body so no problem.
Have any of you run the(67-70) later hi-po manifolds on 66 b-body? I am building a 512" RB and want to use hi-po manifolds instead of headers. I do not really care about casting numbers as long as the 67-70 b manifolds will work. I want it to look stock or close as possible without giving it away. Yep, CH4B intake, CNC Stealth heads, 11:1 compression, mid 500 lift hydraulic roller, and all painted turquise blue with unsilenced period correct air cleaner.
YEs, see my post above. The RB block shouldn't make a difference.
