High beam indicator on when the low beams are on...
Mattkowalski
2:19 AM
Spokane, WA
Anybody ever experience having the instrument cluster high beam indicator come on when the low beams are on, but not when the high beams are on? All the lighting seems to work fine except this one weird thing...
Might be more of an issue, but it happened to me when I first got my car. I started with all the grounds to the lights. Found two were not properly grounded and one light not grounded at all. Fixed them and things were good. Good luck!
I've been trying to track all the grounds down. Wish the wiring diagram in the manual was a bit more clear on what was a ground or hot. I think there may only be one actual ground that I've identified as a lighting ground... I will check them again as well as the dimmer switch.
