lewtot184
as a first test take the cartridge out of the filter that is on the suction side of the pump. look carefully to see if there's any foam or debris on the cellulose. if you find any debris then you need to check the screen that the inlet side of the pump should have. reassemble without the cartridge and go for a test drive. another thing is make sure the jetting in the carb is a least what the carb came with OOTB. i'd bet a dollar to a donut you have a fuel delivery problem that can be easily fixed.Holley black pump, aeromotive canister filter before the pump, then another filter after the pump. #10 fuel line from cell to pump all the way to pressure regulator. Return line is also #10.
