holley 3310 swap
moparjohnny
1:39 PM
ga
i have a edelbrock carb now and wan to replace it with a 3310 do i need to make any changes to the accelerator pedal cable connection to the holley carb? thanks
You'll need the mopar bracket that attaches to the linkage for the cable is all!
I've run a 3310-3 750cfm on a stock cast-iron intake & it worked great. If you don't have any type of spacer on it, you'll need to "very lightly massage" something on the secondary shaft, passenger side, if I recall correctly. Just grind off 1/8" in one little spot...piece of cake. I remember attaching mine without the Mopar throttle linkage. I just found a convenient hole in the primary throttle lever & ran a small 25-cent hardware store nut & bolt through the hole & the throttle cable end & slid the throttle cable up or back (?) a 1/2" so it would hit WOT.
