RebelRider
I'm working on my 70' RR with a close to stock 383. It has a 750 Holley street avenger on it, with vacuum secondaries. I'll be the first to say, I'm not real familiar with these carbs.
The carb had been sitting, so I put a full rebuild kit in it. I got everything bolted back on the motor without any issues. The carb is getting fuel to the bowls, but will not pump any fuel through the jets. Some cases I can pour a little fuel in the carb and it stay running as long as I'm on the throttle while feathering it.
What should I look for that may be causing this issue? Is it something as simple as an adjustment?
