Iceman55
That's a standard square bore manifold, just need to add that spacer to give your carbs linkage some clearance and call it good... beerthirty
Phenolic is a resin made by combining phenol and a aldehyde, so technically it's not a plastic. Some times classified as "Bakelite" It's often combined with various substrates ( canvas, glass etc.) and is compression molded. Sorry I went a little geeky.Thanks 747mopar. I found a 1/2 spacer at summit Holley 17-59 but is phenolic plastic. Is it plastic to help with the heat? is plastic something I would want to use?
To answer your question, yes it will work on your application and yes it will help your carbs heat percolation issues.
