Wietse
OK that makes sense... Thanks man... Ill give it a go hate to spend 88 bucks though. lol But on that same note. Why cant I just come off the negative side of the coil straight to the tach like it was before? Does it have something to do with the ECU and tach signal? Trying not to be annoying but also trying to make sense of it too.
It's a bit off my head too but from what i understand is that the "modern" ignition an coils have a different type of pulse wave like shown as below sample.
The modern systems have the square wave type where the old system work with the top one and are not able to give a good indication due to this.
I might have them backwards as well, but that is what i understood from it, i think you get the idea though.
Edit: There is another type of adapter, which is the #8910, but this is to be used for systems with a ballast resistor.
