Homemade sway bar lower control arm tabs
Encswsm
4:10 AM
Mobile Alabama
I have a “new to me” 1966 Charger I found somthing weird that the PO did. Has anyone ever seen steel plates bolted to the LC arm for attaching the sway bar? This looks sketchy to me. Any suggestions to do it correctly
That looks like some backyard, 3 buddy’s, and a 24 pack kinda job. I would take it all off and save up $200 to $400 then buy an after market kit made to fit your car. Google it. Congrats on your new car
See if you can find lower control arms with tabs.
Removing and installing new bushings is one of the tougher jobs on a Mopar.
It is possible to cut the tabs off and weld them on arms with out the tabs.
I'm a Redneck hack myself and I agree that configuration looks beyond sketchy to me. The suggestions above are spot on. LCAs with the sway bar tabs aren't that hard to find if you look.
Good luck!
That would be best but he will still need a different sway bar. The OE goes on the inside of the radius rods
So, agree with all the others... this is a hack job and would fail under any real work. Also, it's already broken and not functioning. I would remove as soon as possible, if for no other reason - safety.
I would actually recommend Hellwig (Hellwig 5903 Hellwig Anti-Sway Bars | Summit Racing) for the front and Hotchkis for the rear (Hotchkis Sport Suspension 2255R Hotchkis Sport Suspension Anti-Sway Bar Kits | Summit Racing). I've used Hotchkis for the front before and they're excellent! However, the HellWig is - IMHO - a more elegant installation and doesn't require welding.
BTW... congratulations on the new car! I have a 66 Charger and although the second gen get's all the attention, my heart is in gen one Chargers. Amazing cars... I love them.
Hellwig makes a really nice sway bar that bolts to the bottom of the shock.
Super easy install.
IIRC there are two different factory bar setups based on early or late production.
Looks like you need both the bar and the LCAs and will likely require some bushing work and an alignment to get back to the factory setup.
...but if that's not important to you, refer to the first line.
It's a better performing bar and it's way easy to install without any other purchase or work.
Don't the OEM tabs attach here-
The OP might not even have the correct bar.
I welded a flat piece of metal like that to a couple of control arms on this car:
The end links do have bushings in them though. I've driven the car on and off road since 2005, sideways drifts on dirt roads mainly. The setup has held up well. It isn't pretty or elegant but it works for a car this ugly.
Interesting, thanks.
My Coronet is where I circled.
Might be ugly to you but it's a car that I wouldn't mind having....and would drive it as is so long as it ran good.
NOT an ugly car.
CA and "dry state" guys have a funny sense of what "ugly" is and what a "rust bucket" is.
I don't mind the ugly with that car. It is a lot of fun on dirt trails. The car handles great and can pitch sideways with great control. To paint it would really cut down on what fun I have with it.
Well I wasn’t sure, but now I am. As much as nobody wants to believe that these were a bolt on that came with a bar way back when, I suggest to you they are. The OP is in Alabama and I am in Alberta. I got a sway bar that came off a 68 Baracuda a few years back. It came with LCAs included. Guess what was bolted to them. Yup. The exact same pieces. I doubt the same guy moved from Alabama to Alberta and built a set for a Charger.
Here's another option offered by Hotchkis that I will be using. Below is a screenshot from their website.
The ones on the left are the 66-69 Sway bar tabs.
When available, they were like $50 or something? Look very close to stock. But I think the metal is almost twice as thick.
