Hood pin mounts...needed!
TommyShameless1978
6:11 PM
Florida (unfortunately...)
Feedback: +0 / =0 / -0
Hey everyone! :)
I have a 68 Satellite, and it came with a lift off six pack style hood. No hinges at all! No latch, either. It has the hole at all four corners for the hood pins. The car came to me before the previous owner was actually able to install the hood pins, and there are no brackets for them anyway.
I have seen some cars on here that look like they have the hood pins mounted to brackets at all four corners, so I assume I need those brackets. Does anyone here have a set? And are there any specific hood pins I should use? Aftermarket hood pin kits?
Tommy
I have a set of the rear brackets that the pins mount in, and I think one set of brand new pins kit (of two) that I'll sell you cheap. The rear brackets I had on a car for under a month, then took them off. I painted them black.
I already got a set off of Year One, and a pin kit from Dale's Cuda Shop.
I HAVE noticed that the holes in the hood for the rear pins are not in the right spot. Not sure how on Earth that happened. I bolted the brackets where they go, and they don't line up with the holes. Looks like I'll be glassing the hood over and drilling new holes there. Or drill new holes in the inner fenders for the brackets. Not sure which would be the best choice right now.
