Hood turn signals 72 Runner questions
tommyg29
12:28 PM
Miami
Trying to find them, theyre listed as code L31 on my fender tag, and I have the little covers still mounted on the hood, but....no lights or wiring. Doing some searching and I dont see anything specifically for 1972. Would 71 fender signals work? Classic sells them for "71 Roadrunner fender"
Thanks, just trying to sort a bunch of stuff and get the old bird back closer to its former self.
I can't tell you for sure. But on the plymouth 67/68/69/70 GTX/RR/Satelite have the same fender lights and are interchangeable. It would make sense that Charger did the same with a group of their bodies of the same style. The years make good sense. Someone will confirm.....
Yes, the fender & hood mount signal indicators will physically interchange for the ’71-72 application. Difference may be the length of the wire lead, hood mounts may be shorter as they will connect near the bulkhead connector. Parts manual does not specify a difference however, PN 3587504.
Looks like classic sells them, but now need to also find the connector to plug the bullits from each signal into. I cant seem to find a trace of where they might have connected to in the harness, nor anything in the service manual about them at all.
Check page 5-60 in the Body Electrical section of the FSM. Female bullet connectors just double off the forward lighting harness at the bulkhead connector.
Found them!
Thanks for the picture. They were hanging down near the oil pressure sender. One of the female connectors is missing but that should be an easy fix.
Those green red wires for the wiper motor....mine are all bare copper, the insulation has fallen off. Looks like Ill need to address that too, but one thing at a time
