Hope I'm posting in the right forum...but don't know!
G-man69
10:18 AM
Niceville, Fl
Hey everybody, I'm a new member and have been trying to post a question but this is the only place that I've found that will allow me to post. Got a question about electronic ignitiion for a 440 6 pack. Is this the right place (welcome wagon) or should I be somewhere else? Thanks.
Welcome from Alabama, Electrical and Ignition is the proper part of the forum. Get welcomed first and then post your questions in that category.
Welcome to FBBO
you should post it in the proper forum mentioned above
you can get a simple CDI Chrysler Electronic Ignition conversion kit
distributor, CDI control box, coil, appr. ballast, wiring etc.
at most Summit, Mancini Racing or Jegs etc.
www.4secondsflat.com at 'FBO' is a good source
they will curve the distributor for you
they have a great controller too, no need for the ballast
plug & play if you have the wiring already
Rev-N-Nator is another one www.thertgarage.com
good ignition control box
there are better ignition systems
but if you want a stock-ish appearance the Chrysler Electronic are good
I could go on, but go to the proper forum, is best
this is a basic diagram
IMO this is the best, 73 & later style
for the stock-ish to mild performance ignition
the Chrome Box is better
then the orange boxes,
unless you can find or have an old org. Direct Connection era boxes
then the orange boxes are pretty damn good
but DC Chrome Box is even better, more spark dwells, more RPM range etc.
the Gold box is race box only
Chrysler Electronic Ignition Wire Diagram 4 pin Ballast & Electronic Volt. Regulator.jpg
Welcome from Missouri!!
Welcome aboard!
Welcome. If you can't post in the Ignition forum it's probably because you are too new here. Kick back, get acquainted with the fine folks here and post up some pics of your ride.
