horn and window help
luvthyapril
3:14 AM
Baldwin Park So. Cal.
Hi all fbbo fans does anyone have a picture of what's under the horn ring so I can see what I'm missing also on the rear quarter windows what type of roller is used in the third slot of the
window track I thought it was the same as the front two slots but the guide track is bigger on
the third one any help is most welcome.....Thanks Anthony:usflag:
1966 coronet 500 2 door 383/727
I have the panels off my 67 coronet, I'll try to get a picture tomorrow if you think they might be the same.
I'm Not Sure Which Roller You're Referring To But Here Are Some Pictures. Let me know specific areas you need pics of and I'll try to help you. Example : front center rear top bottom ect.
20161007_230441.jpg 20161007_230446.jpg 20161007_230634.jpg 20161007_230725.jpg
Hi rt it is the one at the rear of the window that I'm interested in the track is wider on that one and what ever type of roller goes in there is the one I'm missing on both sides so i need to know what type of roller it takes and where i can get them. Thanks for any help. Anthony
Corrected typo in title for you. :D
I believe that the top left picture is the one you want. I'll double check it this evening. It has 2 rollers one on each edge of the outside of the track. nothing goes inside that track only the outside edges. you can see the rollers in the picture. as to where to find them I can't help you there.
the short one is the one I'm missing the roller for. And it's much wider and thicker than the one for the front of the window as you can tell from the picture
Okay i found something in the service manual on my missing roller for the rear track and it looks like its called a slide and does go inside the track and is probably a 66 only item so if anyone can help me get a hold of these I'll be forever grateful. Anthony.
P.S. see picture from manual
