How the hell do you get the horn ring off of a 65 Coronet 500?? I thought it just twists off but I have put some real pressure on it and no luck, any secrets would be greatly appreciated. Thanks, Jim
You could look for screws behind the steering wheel arms, but I think it should twist off. It could be a little tight, and you could also download the 65 manual to know for sure.
I disconnected the battery, and pushed down on the center of the trim ring and turned it left. I believe there are 3 prongs on the underside, you won't break them...might bend a little bit. That's how I got mine off.
