Daly
So I have a few more questions to ask...
The first is, has anyone done this and was the outcome worth it?
http://www.designed2drive.com
I'm wanting to upgrade the ignition and starter systems on my Coronet and someone had mentioned this swap to me. It allows a GM HEI upgrade to the resistor style Mopar distributor. It piggy backs the resistor with a stock coil or replaces it all together with a 1.0-2.0 ohms performance coil...
The next question is, to run a new ram pick up "mini" starter, is it a direct swap or do I need to change any wiring or such?
And lastly, I bought new gauges for the car and the kit came with a Volt meter instead of an ammeter. Do I need to by pass the ammeter still for other systems or delete it all together and run new wires for the volt meter? I'm just getting into wiring and just need answers to confirm my thoughts. Which is to bypass...
