How to add trunk light
Huicho417
6:42 AM
San Antonio , Texas
I recently went to my local pick and pull classic yard and found a Polara with the complete system for the trunk light. My 67 Coronet had the small bracket for the light just never had one. It fits just right and even had the hole for the actual lamp holder. Need help on what wire wire to connect to to power this light. The pink wire in the picture attached is the one coming from the trunk light. Thanks in advance.
Connect it up to the pink from the trunk to the nearest pink either behind the kick panel or under the dash.
there should be a yellow coming from the trunk light switch connected to a good chassis ground and from the other spade on the switch up to the other side of the trunk light.
