how to convert 4 barrel carb to fit a 6 pack air cleaner
moparjohnny
5:53 PM
ga
would love to make a 6 barrel breather and top with base to accomodate a single 4 barrel carb so i could buy the black fiber glass 6barrel hood without having the 6 barrels underneath? thanks
?????whut???? Ya know, they made GTX's with 440 4 bbls, and Roadrunners with 383's and they all were available with an air grabber.
It's a 69-72 N96 Dodge Ramcharger or N96 Plymouth Air Grabber, Cold air, air cleaner &/or package, also a non-cold air package air cleaner, they don't have the same base as the A12 flat pan, that is for the 6bbl/six pack lift off fiberglass hood... Try Mancini Racing tech line for dimentions
You could make a pan aluminum &/or fiberglass, like the flat 6bbl A12 type pan {1st & 3rd photo down} with side rails turned up 90*, with drains front & rear to drain off water &/or fuel away from air filter element, the manifold or igniton etc. & the rubber seal, to seal it to the bottom of the A12 six pack/6bbl lift off type hood opening.... {2nd photo down is 1969 N96 Air Grabber & 4th photo down is1970 N96 Ramcharger photos}...
