Centerline
I made the decision early on that I need AC in this car... (south central Texas) but I didn't want the lines running all over the engine compartment like the stock lines do. So.. I ran them a bit differently. I used a Bouchillion Performance compressor mount which locates the compressor low out of the way on the driver's side where the power steering pump would be... if the car was so equipped. Then I ran the lines under the battery tray to the front side of the radiator support to get them out of the engine compartment. From there they go to the condenser and across to the passenger's side of the radiator support and back into the engine compartment to the dryer. Then down the passenger's fender and into the air box and to the AC evaporator unit.
Results were a clean unobtrusive installation. Still need to make a cover for the air box inside and add a clamp or two on the lines running down the fender just to make sure the lines stay put.
AC is a Vintage Air Gen II, Super Cool Climate Control, Universal unit, Sanden shorty compressor, condenser was sourced off E-bay and everything else (lines and fittings) are Vingage Air.
