268RTs4ME
- 1:57 PM
- Oct 2, 2009
- Polpar Bluff, Mo. 63901
I have TQ 6460 late 73 early 74. when I took apart to rebuild noticed places in bottom plate were full of gas, so this is telling me that bowl must be leaking somewhere, visually I see no cracks or breaks, nothing looks warped, so is it those two metering well on bottom of plastic bowl, if it is are they repairable, if not could anybody inform me as to what other carb bowl would fit it, I have about 8 thermoquads, however am trying to keep correct dated carb on it. Thought my problem was solved when I found this. Metal fuel line from gas tank to carb had been rubbing on k frame for who knows how long, hole wasn't that big until I buffed it off, this fuel line leak caused me to put in plugs, wires,pick up control box, fuel pump and fuel filter, and bought carb kit, it was a hard one to find, down by motor mount on a 440. and cost me about $250.00. so don't want to do rebuild on carb unless bowl leak can be repaired. Thanks
