I have headlights, but no parking, tail lights, dome lights or dash lights: '67 Coronet
Stink
New Member
8:17 AM
Whitehouse Station, NJ
Hi all, hoping you can help. I have headlights, but no other lights. Replaced fuses, replaced headlight switch. Nothing. Car does start and run.
I'm an electrical idiot - can you please recommend things to check in 1st grade terms :lol:
Recheck the fuse and verify power to the fuse.
I just pulled the fuse box and low and behold, a broken wire. Fixed and lights work, however, no turn signals now. Can hear the flasher clicking away when hazards are on, but not hazards working.
There are two flashers. One for the turn signals and one for the emergency flashers. You can start with replacing the turn signal flasher. Also make sure the 4 way flashers are off when diagnosing the turn signals.
Thanks pnora - sure enough, bad flashers. Turn lights are working now!
Its clear that the Hazard toggle switch is a little crusty. I don't see replacements on the Mopar sites. Any idea where I can get a replacement? Is this a generic switch?
Thanks again!
Thanks again!
Just put a want to buy in the classifieds here. Someone may have one.
