Coronet 14
72 Coronet 318 problem with back fire through carb at full throttle. Dosen't do it all the time. if you back out of throttle when it starts to sputter it won't back fire and will stay running. From a stop you can either take off or backfire and stall the engine. Before I put the electronic ignition in it wouldn't idle or even stay running. The carbs remanufactured. found vacuum leak at charcoal canister. Still intermittant backfire.
