spcedwards214
Ok so I went from a deadhead style system to a return style system. I have a 125 GPH quick fuel pump and ran all new stainless braided -6an fuel line and an fitting to a return style speedmaster fuel regulator. I called the manufacture and they confirmed that the bottom is the inlet, two sides are outlets, and front is return (see pictures). Turning key like that, it pumps fuel out of every office of the carb so it has to be seeing the full 14psi full pressure. But if I run the supply like to the front (where the return was) and return line to the bottom (where supply was previously) and leaving the outlet on the side where it was (keep in mind there is no wording on the billet aluminum regulator as to what is what which is why I called), the fuel doesn't shoot out everywhere but eventually starts to drip inside the carb. EITHER WAY I PUT IT, THE FUEL PRESSURE GAUGE DOES NOT GIVE A READING AND THIS IS WHAT I REALLY DON'T UNDERSTAND, EVEN TRIED A NEW GAUGE. I'm just lost as can be. Someone please throw me some ideas. Thanks in advance.
