i,ve been talking some $#it om here... so heres some pictures
sleepar
Banned
6:59 AM
Ft Lauderdale fla.
i bought the car for $6000 because it was 99% rust free and in really good shape with 55,000 miles.i have waited ayear because moveing to florida from maine was enough and finally about 8 months ago i started assembling parts and ironically i parted out a verry rusted 67 coronet in the early 90's for the drive train to put in a D 150 that became the first sleepar. so i have come full circle and am restoreing 'the parts car'. i have had a 67 318 in all my mopars from a D 500 farm truck to a 99 1500 4x4. i like the simplicity of points and no emmissions.i bought a spedo cluster off E bay that was toast and sent it out to bobs spedomters so if i messed it up its not as big a deal 22700014_0001.jpg View attachment 18884722700009.jpg22700010_0001.jpgconversion to voltsmeter from amp meter.22700045.jpg22700047_0001.jpg22700051_0001.jpg22700055_0001.jpg22700056_0001.jpg22700054_0001.jpg22700058.jpg22700047_0001.jpg22700059_0001.jpg22700073_0001.jpg22700064_0001.jpg these will help me to be able to put things back 22700019.jpg22700021_0001.jpg22700017.jpg22700032_0001.jpg22700100_0001.jpg22700101.jpg22700137.jpgthis was a turning point puting the fromt suspension and brakes together after painting the engine bay inside and out i didnt break the seals on the ac so i was carefull moving the pump around 22700104_0001.jpg22700137.jpg22700136.jpgSSBS this was a lot of fab to mount the booster up with out the extension brackets and with out a manual pedal assembly... the prop. valve is under the dash by the e-brake handle the lines surround the fuse box. i would not recomend this kit go mopar from another year or car and convert mopar to mopar for the same or less money.22700111_0001.jpgnice clean engine bay painted with hi temp engine enamel VHT rattle can i used east wood primer from a can with foam brushes and all the rust spots got some rust converter all my fastners got put ion a mayo jar full of laquor thinner and tumbled around then in the left over eastwood can and on to a plastic sheet then painted 22700121_0001.jpg22700133.jpg22700121_0001.jpg22700173.jpg22700206.jpg22700230_0001.jpgon a 318 i went with the small runner weiand stealth intake and gaslet 22700231_0001.jpg22700232_0001.jpgmatched the ports to the large size port Edelbrock heads22700215.jpg The engine bay turns into my work bench because a pallet fits between the inner fenders space is tight in a 10'x20' storage and i do a lot of cleaning sitting on a milk create and i fill jugs of water but i do have power 22700199_0001.jpgit appears that my timing cover was made in 99 upside down22700192_0001.jpgridge reaming22700256.jpglike magic its done.... If I say whats in there it wouldnt be a sleeper. its got std.bore KB167 pistons on stock crank and shot peened rods every bolt is arp with a mopar windage tray22700190_0001.jpgcam is basically stock 340 specs 22700313_0001.jpg2 days before my girlfriends birthday.... 22700256.jpg there back in i rebuilt the '66 A727 transmission and seals and now im working on painting the underside of the floor
cool stuff, but why is this in the welcome wagon section ??
At least you got out of Maine. Good luck with the project.
The only place I could start a thread and for some reason I can't get my profile picture to work right.
i bought the car for $6000 because it was 99% rust free and in really good shape with 55,000 miles.i have waited ayear because moveing to florida from maine was enough and finally about 8 months ago i started assembling parts and ironically i parted out a verry rusted 67 coronet in the early 90's for the drive train to put in a D 150 that became the first sleepar. so i have come full circle and am restoreing 'the parts car'. i have had a 67 318 in all my mopars from a D 500 farm truck to a 99 1500 4x4. i like the simplicity of points and no emmissions.i bought a spedo cluster off E bay that was toast and sent it out to bobs spedomters so if i messed it up its not as big a dealView attachment 188898 View attachment 188847View attachment 188849View attachment 188850conversion to voltsmeter from amp meter.View attachment 188851View attachment 188852View attachment 188853View attachment 188854View attachment 188855View attachment 188856View attachment 188858View attachment 188852View attachment 188859View attachment 188860View attachment 188861 these will help me to be able to put things back View attachment 188862View attachment 188863View attachment 188864View attachment 188865View attachment 188866View attachment 188867View attachment 188870this was a turning point puting the fromt suspension and brakes together after painting the engine bay inside and out i didnt break the seals on the ac so i was carefull moving the pump around View attachment 188872View attachment 188870View attachment 188873SSBS this was a lot of fab to mount the booster up with out the extension brackets and with out a manual pedal assembly... the prop. valve is under the dash by the e-brake handle the lines surround the fuse box. i would not recomend this kit go mopar from another year or car and convert mopar to mopar for the same or less money.View attachment 188874nice clean engine bay painted with hi temp engine enamel VHT rattle can i used east wood primer from a can with foam brushes and all the rust spots got some rust converter all my fastners got put ion a mayo jar full of laquor thinner and tumbled around then in the left over eastwood can and on to a plastic sheet then painted View attachment 188876View attachment 188875View attachment 188876View attachment 188879View attachment 188880View attachment 188881on a 318 i went with the small runner weiand stealth intake and gaslet View attachment 188889View attachment 188890matched the ports to the large size port Edelbrock headsView attachment 188891 The engine bay turns into my work bench because a pallet fits between the inner fenders space is tight in a 10'x20' storage and i do a lot of cleaning sitting on a milk create and i fill jugs of water but i do have power View attachment 188893it appears that my timing cover was made in 99 upside downView attachment 188894ridge reamingView attachment 188895like magic its done.... If I say whats in there it wouldnt be a sleeper. its got std.bore KB167 pistons on stock crank and shot peened rods every bolt is arp with a mopar windage trayView attachment 188896cam is basically stock 340 specs View attachment 1888972 days before my girlfriends birthday.... View attachment 188895 there back in i rebuilt the '66 A727 transmission and seals and now im working on painting the underside of the floor
:icon_eyes::icon_eyes::icon_eyes::sign18::icon_eyes::icon_profileright:
Dennis...
At least you got out of Maine......
What do you mean by that?
You don't like all the bugs, the cold, rain, snow sleet and all kinds of other crap? Lol
:rofl:
Oh yeah and don't mention parking your car from October / November to about May!
What's not to love?
Sleepar...where were you in Maine!
Thanks for the story and pics. I understand the move to Florida. The frozen tundra begins here in less than 3 months.
Yup, you're right when you say you've been talking a lot of sh!t on here.....
Another sheet talka....right on...it's kin.......Nice looking, well thought out work You do Sleepar
