And... what are your vacuum readings ?
Yes, sure sounds like a vacuum leak to me; at least that’s the first thing to check.
Buy some tools. Start with a vacuum gauge and a timing light.
Do this, do that. Check here, check there. Try this, try that. Replace this, replace that. And yet you don't even know where you started. See these ^^ posts. That's where you start.Basics first would be looking for vacuum leaks/leaking hoses etc:
- disconnect & plug brake booster
- plug ALL vac fittings to the carb or intake manifold
- check spark plugs & cracks in the insulators
- etc. Look for things that age or mileage could cause deterioration.
The factory never used the paper gaskets on standard port B/RB engines. They didn't exist. Nor were they needed.Did they use RTV and/or paper gaskets at the factory? What exactly did the factory use/do?
So i watched a couple videos and these people seem to use RTV together with the gasket:
Is this necessary/good?
If necessary also if you use the additional paper gaskets or is this basically the alternative to using the additional paper gaskets?
Did you diagnose the cruise control for a vacuum leak?Well i already found two vaccum leaks (the intake even leaks on both sides) so i don't think that further diagnosis is needed at this point.
I mean sure maybe there is even more wrong but i will start with those two leaks. Personally i don't really expect more to be wrong (timing, carb tuning etc.) because the engine runs great apart from this idle rpm issue.
Back to the booster - are you sure the booster is bad or is the check valve bad? The check valve is an easy and cheap fix. You can have your current booster rebuilt. I used Booster Dewey (actually Power Brake Booster) last year and it’s working great. Turn around was very reasonable too.
Vacuum Brake Boosters | Power Brake Booster Exchange, Lynwood
Power Brake Booster Exchange rebuilds vacuum brake boosters and supplies hard-to-find booster parts. Find out more about our services online today.www.powerbrakebooster.com
