Idleing
harry heck
7:09 AM
Boston
Just recently purchased a rebuild kit for my six pack. Cleaned and tuned but I still have a bit of a rough and a high idle. If I don't tune it a little high, she tends to stall. What should my RPM be at during idle?
I'm not a expert but believe it should be around 8-900. I think it really depends on your setup; automatic vs manual. I've got an auto and I had problems with mine at 900. I'm up closer to 1k.
I've got an auto and since the rebuild I'm up about 12k
My minimum is just under 1k. Seems better when I get closer to 1100. Then it sounds too high but sounds smoother once in gear. I've got the MP509 cam which creates havoc for idling tho.
Somebody will respond that's way more knowledgeable about this tho.
Stick. Demon 4bl. 750. Enough to sustain idle when ac cycles. Nice lope. Exception at alltitude, bump up 100.
I'm at 800 with a stick shift.
I was at 1200 at idle & now can easily stay running at 800 rpm after I tuned the carbs. Hope this helps.
Gentlemen,
Because of the cam, a Crane equivalent to the Mopar 292 degree 0.509 lift with 1.5 ratio Crane roller rocker arms, and 15 degree BTC static timing, it idles best at 1200 RPM (hot) with the anti-diesel solenoid energized....my car is a 4 speed. Idle is tolerable...only slightly lumpy. Carb idle mixture screws set to provide the smoothest idle at about 13.5 A/F ratio, measured with an exhaust gas analyzer. This is what works for me.
Bob Renton
Go to the Thread TUNING a SIX PACK GREAT INFO + LINKS! Especially about your PROBLEM
