Ignition Lamp & Oil Lamp not lighting
Ragnar
8:51 AM
United Kingdom
Hi guys,
Can anyone help with this? My oil & ignition lamps have stopped working on my ‘73 Charger. Bulbs are ok and the main dashboard backlight and indicator bulbs work. I have given the bulkhead wiring a wiggle, but no luck. Good voltage at battery too. I’m out of ideas!
I would start with the oil pressure switch.
For the oil pressure switch remove the wire from the switch, key in run position and hold to a good ground.
The light should come on. If it does work you have a bad pressure switch.
If it does not then you need to check for power between the ignition along to the the engine harness. It's likely the two are related.
Go to mymopar.com for a schematic to get the wire colors.
