Texas charger 73
73 charger , mild small block, weekend and occasional cruising , is stock ignition fine or ignition box better? i see so many run the ignition box just to eliminate the ecu and the ballast resistor since they overheat and fail... i was just curious on yall's opinion on what your running. pros and cons of stock vs aftermarket?
