RICHIES ARMOR
In need disc brake advice
Hey guys
I need some help.
A lil back ground.
I installed Wilwood front brakes(4 piston) and Wilwood rear brakes (4 piston) on my 73 Saty.
The stopping was only about marginal. I installed a new master cylinder and power brake booster. Oddly it went to almost no brake pressure at all.
I added a dial proportioning valve to the rear and adjusted the rear to very little pressure.
This brought the brakes back to simply marginal again. Poor pedal feel and seems to build better pressure if I pump the pedal first.
I have the master cylinder about 3/4 or so full. Im think I may need to add a lil more fluid and recheck.
When I bleed the brakes I have more pressure at the back than the front.
Any suggestions? Should I add a replacement front proportioning valve.
Thanks in Advance
Richie
Hey guys
I need some help.
A lil back ground.
Thanks in Advance
Richie
