I replaced my mechanical fuel pump with an inline electric pump after a pushrod failure. The Carter P60430 pump I used is rated at 25 gph. If I floor it from a standing start I seem to be starving for fuel half way through second gear. I see the Edelbrock 17301 is rated at 38 gph. That is a 50% increase in flow so on paper it should work, but I don't want to waste my money if it won't solve my problem. Does anyone have any experience or suggestions? FYI it is a 400 big block that made 340 hp on the dyno, but I have just swapped to Edelbrock heads and 1.6 rockers, so it may be up to 50 hp more.
