Mechanical fuel pump for alcohol fuels
Paul_G
7:16 PM
Surprise, Arizona
Does anyone make a fuel pump that can survive for more than a couple years using alcohol blended fuel? That is all we can get at the pump. The mechanical pumps I have tried all die at the two year mark. Edelbrock and Holley now state they are designed for gasoline not methanol or alcohol. The fuel here is 10% alcohol. The alcohol destroys the internal rubber parts. I Have been using external electric pumps. Cant stand the constant buzzing anymore.
get an in-tank pump, there quiet, I have seen kits to cut and install into your stock tank. I believe they hold up to the ethanol added fuels. Had a holley blue pump years ago, loud as can be, not bad if you have open headers :lol:
That is my next option. Problem there is the pressure they produce. They make 50 to 60 PSI. I run a carb needing less than 8 PSI.
should be able to get a regulator for that, they do make smaller in line pumps that are not quit as loud not sure how they hold up
I've been running 6903's for decades on 10% alcohol gas with no issues. I've got one on my 69 r/t that is so old i can't figure out why it won't die!
You must be very lucky. They either stop building pressure or leak out the vent. Cheap or expensive, two year lifespan.
I DESPISE in-tank pumps. I threw away a car I liked when the third one failed and I got an $800 quote to replace it. I have another car that needs a new pump. Wanna guess what the first replacement step is.....?
1. "Unbolt and remove entire independent rear end assembly to gain access to remove tank"
Alternate step 1. (the one I'm gonna use) Cut a hole big enough to drive a truck through in the trunk.
Be glad your outside tank fuel pump is so easy to replace!
