Ok. The dash frame is the same so just need a Rallye cluster with wiper and headlight switches. Radios are the same. The dash wiring harness is different between the two. So you either need a complete Rallye harness are the part of the harness that goes on the cluster and then splice it to your non-Rallye harness.
Also there are 3 harnesses. 71, 72/3 and 74.
Also there is the 71 only cluster and wiper switch.
