red340bbody
:headbang:i BOUGHT THE speedway motors REAR DISC BRAKE KIT .
This kit was meant for a ford passenger car BUT i had a friend make me the proper plates that bolt to the rear axle flange .I ordered a caliper from a 1989 trans am with the built in e -brake system . I put it all together after i filed the rotors flange so i will slide over the axle flange .I have had to modify a couple of things to make this set up work and it has been pretty easy .the last thing i went to do was put on the caliper pins and tighten it up and it was good to go .well i put the pin in tightened them, up to spec and go to spin the rotor NO SPIN ......I have to machine a spot on the caliper pin near the middle of the pin as thick as the rotor and them it will be good to go . the e -brake will be the next thing which i will be using the factory 1971-74 charger rear e -cables and center cable so it will look factory in a sense if so one happens to take a boo under neath... hope to have pics soon ...
