Huicho417
My engine leaks a few drops of oil under the front side of the intake manifold when I drive on the highway. It’s a 318 with an edelbrock carb and performer intake. I did make sure to only use the gaskets on the side rails and sealant along the front an back. I’m sure I did not add enough sealant along the front China wall and that is what is causing it to leak. My question is regarding the small tabs from the head gasket that stick out. Do these need to be cut before installing the intake, or is it ok to leave them? I know they interlock into the cork gasket when one is used. But thinking about I logically it seems like this may be a potential issue when only using sealant.
