iron 426 hemi head info
63fury500
8:31 PM
Beaver Dam, Wisconsin 53916
Looking for info on how to install iron hemi heads,getting arp bolts,needed to know torque sequence and any other info on the valley area head bolts,sealers?oil threads?thanx
The ARP kits come with moly lube. Torque in the sequence per factory Chrysler manual and use ARP's Torque specifications per their instructions.
Use cometic gaskets only and silicone around water coolant ports, also remember you will need wish bone wrench for valley bolts for torque wrench extesion
Are you using head bolts or studs? Have you been able to find them in stock anywhere? I am looking for a set of ARP head bolts for a 426 Hemi the part # I'm looking for is #145-3901
Thanks, JKent
summit hasnt had any in months and dont know when they will get more,arp is a joke of late
Yes, just like everything these days. Everything is on back order. I have hundreds of head/main bolt and studs kits along with thousands of bulk bolts that have been on back order with ARP for several months now. Raw materials have become a bitch to get in these days also.
